Hammering Logo
albert bilodeau Posted on Oct 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i trobule shoot my bosch hammer drill, does not turn on
Model 11255vsr
john h
Level 3:
Top Expert:
  • Bosch Master 29,494 Answers
  • Posted on Oct 16, 2019
john h
Bosch Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7558503
Points
193449
Get a multi-meter and test switch and wiring
5 Related Answers
Roscoe007
  • 101 Answers
  • Posted on Dec 16, 2008
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Anonymous
  • 2176 Answers
  • Posted on Mar 07, 2009
SOURCE: Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Anonymous
  • 154 Answers
  • Posted on Apr 13, 2009
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Anonymous
  • 211 Answers
  • Posted on Dec 16, 2009
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Anonymous
  • 79 Answers
  • Posted on Jan 15, 2010
SOURCE: No hammer effect, motor work OK
First try the switch for hammerdrill/drill action. If it feels loose, then its internal. if it feels ok, then your hammers on the cage are stuck, frozen or worn.
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
How do I remove the striker pin on bosch 11224VSR
If you mean the front striker pin you will need to remove the circlip up inside the spindle. You can see it through the two little holes just above the spring.
1helpful
2answers
I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
1helpful
I bought a used Bosch Bulldog hammer drill on the internet some time ago and discovered it's not hammering. It will drill be almost no hammer action. Any suggestions?
There is an o-ring on the striker that will wear down over time, this needs to be changed, of worst case the striker has stuck in the hammer piston. Both these repairs should really be done by a service center as these hammer drills are complicated to repair if you are not familiar with them. Any Bosch service center will be able to help you. Just go to the Bosch website and find a center in your area.
1helpful
My bosch bulldog wont hammer any more, can it be fixed?
sure it can, is it just not hammering or is it making a noise. If not hammering the o rings to replace cost about 15-20.00 plus labor, if it is making a funny noise then you might have a major problem.
1helpful
Hammer drill just stopped working. Any ideas?
Usually that is a good sign of the switch going bad...
heatman101
Looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
Top Bosch Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
jabbar huusain
jabbar huusain
Level 1 Expert
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
