SOURCE: SCOOTER WON'T GO BUT 2 MILES HOUR NOT 7
Be sure that the batteries were tested with a load tester. If it is not the batteries then ohm test the brakes. It should be around 35 ohms.
SOURCE: My mother is using this mobility scooter and at
Hi. A faulty speed control pot ( wig wag ) will cause this problem.
While you are driving along on a smooth surface, move the end of the lever carefully up and down, not in and out as you normally do. Doing this will help to see if there is a problem with the pot, it will cause the speed to vary or change.
Can sometimes be caused by stuck or worn motor brushes.
Good luck. Neil.
SOURCE: I have a Chrysler Town
Chrysler products allow you to program the computor for the tire size on the vehicle. I have no idea how this could have been altered, but find someone with a scanner and have them give that a shot.
SOURCE: why wont my scooter gain speed?
it could also be air filter. check your throttle cable for kinks or need to adjust .
SOURCE: Can i get more speed from my 2016 bms 150cc heritage scooter
it is only a scooter
you should have bought a motor bike if you wanted speed
check that you are getting full throttle
take it in for a service and complain about the lack of speed
