Hi Vili Odor, if you mean the transformer or the source and amplification board, in either of the two elements, you can change them, since they are the same
I send you the links to download the service manuals of both teams
Comment the results
Regards Franco Dosil
Hola Vili Odor, si te refieres al transformador o a la placa de fuente y amplificacion, en cualquiera de los dos elementos, puedes cambiarlos, ya que son iguales
te envio los link para que descargues los manuales de servicio de ambos equipos
Comenta los resultados
Saludos Franco Dosil
https://www.manualslib.com/manual/1423342/Teac-Mc-Dx32i.html
https://www.manualslib.com/manual/1321289/Teac-Cd-X10i.html
You can but be shure to measure the voltage that is required by the two units, also check that the polarities are the same. The current consumption should be fairly the same
SOURCE: TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
SOURCE: teac cd-x10i
SOURCE: TEAC MC-DX32i suddenly the Subwoofer
I have several of these units due to being a liquidation seller, and the MOST common problem is the subs not getting any power. Next is CD Player Dying, and 3rd, unit powering, but not sending info BACK to the sub.
In any case the issue with the subwoofer is rarely the fuses. It's further up the line. So far every unit we have checked the transformer was the culprit. If you are handy, by all means replace the transformer and you're better to go.
SOURCE: I need the code for a Teac CD-X10i mini hi fi
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software
you can download from here.
Once installed, you will simply
run the software, and select the devices you would like to control from
menus. The software finds the right codes for you and loads them into
your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual
Download
Logitech Harmony
Firmware Update
Harmony Win Software
Download
Logitech Harmony Safe
Mode Fix
Harmony Remote Glow
Light Fix
SOURCE: Teac MC-DX20 CD
http://www.orangechimp.com/_e/Teac_Replacement_Parts/product/Teac_Parts/Teac_Original_Replacement_Spare_parts.htm Email them for spare parts quotes.
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
