Cameras Logo
L
Lynn Muller Posted on Oct 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MINOX DSC flash not working
How do I charge the flash on my MINOX DSC camera/ viewer. It doesn't charge or come on when plug into the camera and it doesn't seem to have a place to plug in the usb charger that charges the camera it's self
Tony Parsons
Level 3:
  • Minox Master 6,405 Answers
  • Posted on Oct 15, 2019
Tony Parsons
Minox Master
Level 3:
Answers
6405
Questions
Helped
1652122
Points
20272
From the manual (which you could have consulted yourself, I would have thought) :
Charging the battery in the flash module (DSC Flash). Use the provided power supply cable (mini jack to USB) to connect the flash to the USB port of your switched-on computer. Charging commences automatically.
To charge the battery of the flash module without the computer you can use an optionally available power adapter.
A green LED lights up while the internal battery is charging. Charging is complete when the green light goes out.
5 Related Answers
Anonymous
  • Posted on Sep 26, 2008
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Anonymous
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
A
Anonymous
  • Posted on Oct 01, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Anonymous
  • Posted on Apr 06, 2009
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Anonymous
  • Posted on Jul 02, 2009
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
DSC-H9 flash doesn't work
You can buy a flash unit for your camera from E-Bay listed under camera parts for your make & model but this may not be the cause of your problem. you really need to have it checked before you start buying parts that you may not need.
5helpful
2answers
Lost the user manual for Minox DSC. Where can I find one?
http://minox.com/index.php?id=1139&L=1&file=fileadmin%2Fdownloads%2Fproduktinfos%2Fdigitalkameras%2FMnx_Prospect_DSC-Silver_0410_05_en.pdf
Digital player not charging
need an opperation manual for minox DM 1 Digital camera
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
Top Minox Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Minox Camera Expert? Answer questions, earn points and help others
