SOURCE: salt water pump worked good now will not go to cholorine, no code
I EAS GOING TO UPGRADE TO A SALT PUMP FOR OUR POOL LET ME DO SOME RESEARCH ON THIS FOR YOU
SOURCE: my water softner pumps water into salt container,
Your line running from the softener has an air leak, inspect your connections, redo them to ensure sealing
SOURCE: intex salt water witha 18x48 witha 2000/gph pump.
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
SOURCE: My salt water pump constantly
93 is sleep mode
after setting the # of hours you want the pump to run and it runs those hours it then goes to sleep mode
If you do nothing the unit will come on again in 24 hours and then run the same amount of hours as previously set
If you want to change the hours then un plug and re plug in
Every day could be different some days you may need 4 hours or so and others upwards of 12
SOURCE: I have added salt due to constant low salt
Way too high on the salt.. about 5000 to 7000 ppm. You should be around 2000 to 3000 ppm or 5.6 to 6.6... I had the same issue with my system and it's always the cell..Look inside the cell and if you can see white stuff inside, it needs to to be cleaned... The manual states to soak with vinegar for 6hrs.. I soak mine for 24, flush and soak again for 6hrs and flush again.. Comes our clean.. and the low salt alarm goes away until the next time the cell gets dirty with the white buildup... You can add an additive made by hth called "Cell Saver"..Prolongs the cleaning cycle... After you clean the cell and your filter, change your chlorinator cycle to 10 hrs with your pump to run 11 to12 until the pool clears and then lower to maintain the proper chlorine level.. Good luck and hopes this works for you.....
Testimonial: "I am soaking the cell now. Will check it tomorrow and see what happens. "
