SOURCE: How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
