SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
SOURCE: I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
SOURCE: connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
SOURCE: i cant save sim city 2000 on my ps3
Make room free on your ps3's harddisk, this is where al data on your ps3 is stored.
Some games install alot game data, resulting in a harddisk thats is full.
Remove game data from games that you're not planning to play any more soon.
SOURCE: No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
