SOURCE: JVC LT-32DY8ZJ FUZZY PICTURE
Fixed my problem, took it back, got refund and bought a different telly !
SOURCE: Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
SOURCE: JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
SOURCE: JVC LCD have sound no picture
it can be either the backlight inverter board or the power supply module is not supply 24vdc to the inverter board.
SOURCE: i have a jvc tv lcd model lt-42e488 the green
is a inverter control board defective, need to be replaced.
