I have the Hobart N-50 Service manual and have removed the drip cup and driven out the taper pin. The planetary, even with moderate persuasion, will not come off. Looks like the shaft may be seized to the planetary.
Try this.
Take two flat blade screwdrivers and slip the blades between the planetary and the mixer body (on opposite sides) pry it off.
This has worked for me.
Testimonial: "Thanks, John, for your suggestion. I was able to complete what I wanted to do (renew grease, ensure gears were is good shape) without having to remove the planetary. Have the N-50 back together and it is running smoothly so I shall leave it for now. Will try your approach when I need to service again."
SOURCE: Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
SOURCE: How do I remove the beater shaft on Hobart H600?
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F13447.pdf
Click Link above. It is you Instruction and parts manual.
Hope that helped
SOURCE: RING, PLANETARY DRIP
I push down with kniffe the chrome ring and remove the agitator shaft that was broken
SOURCE: hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
