Coffee Makers & Espresso Machines Logo
L
Labied Razzaq Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nespresso Magimix M300 keep showing fill water. Tank is full, but it does not work.
Gerald buhagiar
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jan 12, 2021
Gerald buhagiar
Expert
Level 2:
Champion:
Answers
205
Questions
Helped
243603
Points
305
At the back of the water tank which is inside the tank, there should be a floater that will correspond to the internal PCB commands or if you like sensor. if what is full floater should go up if the water is low floater is down.
2 Related Answers
A
Anonymous
  • Posted on Oct 07, 2007
SOURCE: Just says 'fill water'
this has happened to me. try opening the steam wand (but without the steam function turned on) to force hot water out. that usually gets it going for me.
Anonymous
  • Posted on Feb 03, 2009
SOURCE: Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
11helpful
4answers
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
2helpful
Manual instruction in pdf doc
The manual can be found at the following location:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
2helpful
Try rescaling the machine.  The following is a PDF of the instructions:
4helpful
2answers
4answers
1helpful
Nespresso magimix M300
Sounds like it is deffective.  If it's under warranty (under 1 year old) Nespresso will pick it up at your residence and fix it/replace it for fre.
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
