Exercise & Fitness Logo
T
Terry MacTavish Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Checking speed sensor on series 7 bowflex treadmill
Joseph Massimino
Level 2:
Habit-Forming:
New Friend:
  • Expert 67 Answers
  • Posted on Nov 02, 2019
Joseph Massimino
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
67
Questions
0
Helped
22942
Points
166
Bowflex company is alive and kicking, did you try calling them for the best information? Don't let them try to sell you a new machine unless they give you a great big discount, ask about repair.
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Feb 21, 2009
SOURCE: Err LS on Bowflex Treadmill
The machine needs to be re-callibrated. L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
The instruction book doesn't mention calibration. be sure to not callibrate in metrics, however (there's no way to easily tell the difference - you have to ask) or you'll be strolling like a walk in the park at 5 "mph".
Thanks for using FixY - a FixYa rating is appreciated!!
Anonymous
  • 64 Answers
  • Posted on Nov 17, 2009
SOURCE: I have a Nautilus Bowflex 5 series treadmill.
I will have to check the error code but sounds like a heat problem. When you get too much friction between the walk belt and the deck it builds a lot of heat which creates more drag on the motor. This causes the motor to overheat which in turn usually shuts the machine off. You can let it cool and go back exercising until the cycle repeats. If this sounds like your issue, try lubricating the walking belt. If it's not in bad shape it should make a difference. The machine should run longer. 10-15 is pretty quick though so it make take a couple of application of lubricant. The belt may need replacing if the need for lubricant becomes too regular.
Anonymous
  • Posted on Dec 21, 2009
SOURCE: bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 05, 2011
SOURCE: incline motor is not working
Dear Sir:
1) If everything is working , now the only thing you can do:
2) check the Motor Lift the Voltage DC ( direct current) is diffferent from the Motor Drive that work with 115 VAC( Voltage alternating current). See the Voltage in the plate of the Motor if 48Vdc or whatever voltage is indicated.
3) Check the breaker and reset , and clean with solution with 50% oxigened water and 50& ethilic alcohol (100%).
4) If all is clean, turn on the motor Lift, and See if there are voltage and the terminal Motor( Check with VOM-Voltimeter in the range DC,) .
Check again the voltage indicate in the plate of Motor, if the Motor is NOT Working, the Motor is Bad( Some brushes wear, and winding overheating) replace or repair.
Conctac me, if you need some additional Help.
sincerely.
Have a great time, blessing.
E.CUADRA
parts4treadm
Alma chee
  • 69 Answers
  • Posted on May 28, 2015
SOURCE: sportart 6310 treadmill - check speed sensor
This may be helpful: http://www.treadmillsrepair.co.uk/2014/04/speed-sensor-for-treadmill-error-e1.html
I have a tc5500 bow flex tread climber it is showing a 070 error code what dose this mean
The error code 070 on a Bowflex TreadClimber typically indicates an issue with the speed sensor or the speed sensor circuit. This error can occur if the speed sensor is not providing the expected feedback to the treadmill's control system. Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. **Inspect Speed Sensor:**
- Locate the speed sensor on your Bowflex TreadClimber. It is usually located near the drive motor.
- Check for any visible damage, loose connections, or misalignment. Ensure that the sensor is properly positioned and the magnet is in place.
2. **Clean Speed Sensor and Magnet:**
- Dust or debris on the speed sensor or magnet can affect its performance. Clean both the speed sensor and the magnet carefully.
- Use a soft, lint-free cloth to wipe away any dirt or debris.
3. **Check Wiring:**
- Inspect the wiring connected to the speed sensor. Ensure that there are no frayed wires or loose connections.
- Follow the wiring from the speed sensor to the control board, checking for any signs of damage.
4. **Test the Speed Sensor:**
- If you have a multimeter, you can test the speed sensor for continuity and proper resistance. Refer to the treadmill's user manual for the specifications and testing procedures.
5. **Inspect Drive Motor:**
- The drive motor plays a role in the speed control system. Check the drive motor for any issues, and make sure it is running smoothly.
6. **Reposition Magnet:**
- Ensure that the magnet (usually attached to the pulley) is properly positioned near the speed sensor. It should pass by the sensor with each revolution.
7. **Perform a Hard Reset:**
- Turn off the treadmill, unplug it from the power source, and wait for a few minutes.
- Plug it back in, turn it on, and see if the error persists.
8. **Contact Customer Support:**
- If the issue persists after performing the above steps, it's advisable to contact Bowflex customer support or the manufacturer. They may provide further guidance or recommend service options.
Keep in mind that these steps are general suggestions, and the specific procedures may vary based on the model of your Bowflex TreadClimber. Always refer to the user manual for your treadmill for model-specific instructions and troubleshooting steps. If you're unsure or uncomfortable with the troubleshooting process, consider seeking assistance from Bowflex customer support or a qualified technician.
1helpful
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
2helpful
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
6helpful
I have an L5 error on the display. Belt not working. What do i do?
This is a LS or speed sensor error, it can be caused by a belt that is too tight, non lubricated walking belt and or a bad sensor. If the belt does not move at all, Bowflex will tell you to buy a new lower control board. $227 direct from them (Nautilus)
2answers
I get an L5 Err message and the treadmill will not move.
sounds to me like your speed sensor fried itself. The speed sensor is on the pulley that turns the belt. If you're under warranty them give bowflex a call. If not under warranty you can still call and order the part. Porbably about $20 for a new sensor.
(800) 952-7205 - Bowlfex Customer Support
3answers
Bowflex treadmill code 05
tHIS MAY BE A SPEED LOSS ERROR. Is the belt moving when this happens? Decribe what lead to this problem in the first place that will help me to better assist you.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
3helpful
2answers
Top Bowflex Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
