Tools & Hardware - Others Logo
Patricia Steele Posted on Oct 14, 2019
How do you get to the belt on a frigadaire dryer
Heavy-duty
Michael
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Oct 25, 2019
Michael
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
2066
Points
19
Have to pull off the front face and panels access from the front of machine
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Oct 08, 2007
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Anonymous
  • 1122 Answers
  • Posted on Feb 26, 2009
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 10, 2009
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
watch the video
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
jamie
  • 1810 Answers
  • Posted on Aug 04, 2009
SOURCE: Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Sep 24, 2011
SOURCE: part number 8066065 kenmore heavy duty super
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Testimonial: "Quick and to the point help. Thank you kindly."
1helpful
My malleys heavy duty 1050 wont tumble.
I could not find much info on your dryer, but there is probably a belt that goes from the motor and wraps around the drum. If the drum is not rotating, the belt may be broken.
2answers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
4helpful
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
5helpful
Dryer wont start.
8helpful
2answers
Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 • Dryers
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
