SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com/products/H45820.jsp - Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
SOURCE: Emporio Armani AR0534, How do you reset the
If it is not working you may need to "AC" the watch. This generally needs to be done when the battery is replaced. This will reset the circuit board and allow the watch to work correctly. There maybe instructions on the inside of the back lid to do this but i always recommend having a watch maker/technician doing it because of the delicate nature of the circuit board.
If the sweep arm is not resetting to the 0 position then you can set by....
pull the crown out to the first or second set position then press and hold down the start button until the sweep arm is in the position you want.
SOURCE: emporio armani AR0203 face glass broken need to replace
If you have no joy anywhere else, you could try the Aramani service center. Below is an extract from their web site.
"If you have questions about Warranty or Repair please contact us at:
800-277-4013 Available M-F between 8:00am –
6:00pm CST
[email protected]"
SOURCE: how do I open my emporio armani watch to change
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
