Electrical Supplies Logo
Kelly Jones Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hw4000 generator wires are cut - Electrical Supplies
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Oct 15, 2019
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198554
Points
1063
If you need more support or need to purchase diesel generator set in the future, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com.
2answers
Honeywell hw4000 generator starts with spray wont stay running
We are a Generator Parts Specialists. We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
2answers
Our generator cut off
Our generator ran for several hours then cut off
How to flash a generator
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Cannon penncraft cannon work
How do i flash my generator to get power again
What can I try next?
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
3helpful
I have a coleman powermate generator 6250 max watts. The black on/off switch wire pulled out off the engine some where and I need to know where it goes. If it goes to the magneto, where is the magneto...
you must dislocate the handle and it's base ...you will find the magnetos in the FLY-WHEEL area.trace it's wireing till you find a cut-off black wire...and reconnect it...
PS. it might be disconnected and not cut...and that way it will be harder to trace..
if u have any further questions email me at [email protected]
Fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
