Sounds like a short to me, go over all connections and retape/crimp as needed. If that doesn't solve problem, go to speaker connections n check secure and not shorting. ....
Also sounds maybe like you have speakers connected in maybe 2ohm load instead of 4ohm. Lmk what u come up with.
SOURCE: DEH-P5050UB
here is the link for your manual
http://www.pioneer.com.sg/storefront/manual/DEH-P5050UB.pdf
SOURCE: AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
http://stereophonik.com/gutterslide/IP-BUS_Hack/
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
SOURCE: need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
