Optics Logo
s
steve Posted on Oct 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need turret caps for konuspro - Optics
Tony Parsons
Level 3:
  • Optics Master 6,405 Answers
  • Posted on Oct 13, 2019
Tony Parsons
Optics Master
Level 3:
Answers
6405
Questions
Helped
1652266
Points
20272
Words cannot begin to express how honoured and grateful we are that you have chosen to share this vital information with us. Had you asked where you could obtain these items, we would have been more that happy to have attempted to help you, but alas, all you did was tell us of your plight.
  • steve
    steve Oct 13, 2019
    Torrets are caps th
  • Tony Parsons
    Tony Parsons Oct 14, 2019
    Well, that clears things up
1helpful
The turret is out of center on sl25mc lathe
The front turret bolts will need to be removed. Remove bolts in face of turret. There should be some adjustable bolts that will allow you to move the turret back in the correct position. Load a precision ground block into OD tool holding slot, usually tool 1 position. Hang it out around 4 inches. Indicate this block within .0005 or as close as you can get it while tightening the set bolts. It usually takes a couple of tries. Also the spindle might be knocked out as well. You can check spindle by cutting between centers. If it cuts tapper then it is also out of alignment. Hope this helps...
How to change my battery on a 4x16x40 centerpoint scope
remove the battery cap, replace the battery, reinstall the cap.
Windage and elevation adjustment won't move on konus 275 scope
you may have run out of clicks or the adjustment internals are damaged
Bullet spares hyderabad
You may need to send the scope into Zeiss to have the turrets changed. The folks at RCS Optics Customer Service will help you out. Email them at [email protected] or contact them online at www.rcsoptics.com
I have a tasco 3x9x50 world class rifle scope. The scope caps are stuck to the adjustment screws in top and side of scope. I am unable to unscrew the caps without unscrewing the adjustments as well. The...
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
1helpful
Is there a way to lower my turret after i've found my zero? my zero is at the 4th vertical tic mark on the 0.
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
1helpful
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
1helpful
I tried to remove adjustment caps from my scope to zero and the entire adjustment assemblies unscrewed.i can not remove cap.
this is what happens when there done up to tight,
get a soft jaw vice and put the thred of the turret into the SOFT JAW VICE!!! (lined with leather),,,,
very gently grip the threds and undo the cap,,,
when refitting the bottom bit to the scope put a small blob of grees on the bearing part,,,oh,,by the way!!,,,
it should be regased! or it could fog up on you when it gets cold,,, only just nip up the turret caps next time
1helpful
2answers
Resident evil 4 cheats
Walk 1.5x faster with Leon
This glich allows you to walk 1.5x faster with Leon. First equip the striker shotgun, and exit the menu. Hold R1 to pick up your weapon and then press the menu button before the laser on the gun is shown. Now you are in the menu because of pressing the menu button you can equip another gun. Now when you exit the menu, Leon will run 1.5x faster than normal. This glitch will stop working after opening doors when the black screen comes up, climbing ladders and selecting the stiker again.
or
Perverted Leon
When you climb up a ladder with ashley, wait until she comes up and then jump back down. You will then need to catch Ashley, instead of doing that, aim your crosshair until ashley's skirt and she'll cover it up and then she'll call you a pervert
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
1helpful
2answers
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
