I have bleed all radiators and its still at max.......any ideas on how to fix this????
SOURCE: oil pressure gauge reads past 80
now unless there is a very loud knocking of the motor which would mean that the engine's top end was not getting any oil I would say that your oil guage is sprung and needs replacing. a high pressure rating would indicate a restriction in the oil flow pasdt the sending unit or a plugged oil filter. if the filter were plugged you would know it because your enging would run tight in no time at all. replace the guage itself... please rate this........thanks
SOURCE: High oil pressure reading
Hi, this is a oil pressure sensor malfunction. the gauge is getting a distorted reading from the sensor. replacing the gauge will fix this issue. also, check the fuse box for blown fuses.
SOURCE: oil pressure gauge is showing max pressure. Figure that sensor is bad???
I agree with you, replace the oil pressure sending unit.
SOURCE: oil pressure gauge shows low / high / middle changed sensor did
Hello mb4494: My name is Roger and I will help you. If by changing the oil pressure sending unit the problem did not change. I would perform a oil pressure test. This is done by removing the oil pressure sensor and inserting a oil pressure gauge. This can be done by yourself or by a repair shop. This needs to be done on a cold engine. Start the engine and observe the oil pressure cold.as the engine warms up observe the pressure. The pressure will drop off as the engine warms up.Should the oil pressure drop below 10 to 12 PSI. then you have internal engine trouble. More then likely a bearing problem. Try dropping the truck into gear and see what the pressure drops off to. Again if the pressure drops below 10 to 12 PSI. you have a problem. I would also check to make sure you have the correct oil switch. a truck with a oil light uses a oil pressure switch. with a gauge you would use a oil pressure sending unit. Sorry for the long reply but want to make sure you check the pressure correctly. Please rate the quality of the answer as this is how we know the answer was correct. Thank You for using Fix Ya. Roger
SOURCE: Oil pressure gauge drops after running and sitting still
The Oil pressure sensor seams to have gone bad and needs to be replaced soon as possible as they tend to leak oil soon after. There common to go bad and start with that since it's easier then replacing the oil pump, but if you don't hear any ticking from the engine and you have good pressure when the engine is cold then it's the sensor.
The 4 cylinder oil pressure switch is located below the A/C compressor. It is a single wire connection with a gray/yellow striped wire.
The 6 cylinder oil pressure switch is located on the passenger side rear of the block. It is a single wire connection with a gray/yellow striped wire.
Good luck and hope this helps.
