SOURCE: sentry 3100 safe_i remember combination but do not remember which way to turn
go around 3 times to the left
stop at the 1st number
go to the left one full time and pass the # but stop at the 2nd #
go to the right and stop at the 3rd # the 1st time you come to it
I just bought one last night
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
SOURCE: samsung J400 forgot privacy lock code,i want to unlock
Hello lovechat1,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
SOURCE: I locked my key in
Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
