It's a Frigidaire dehumidifier. FFAD 70 33RIAO
SOURCE: Dehumidifier frosting up
I have the same problem under 5 year warranty. The Authorized May Tag Dealer (Stan & Pauls), advised that they were unable to duplicate the condition. I then took it home, let it run for several hours and brought it to them with the Evaperator completely frozen in ice. They then ran it in their shop and stated that it will not freeze their. It is interesting to note that this model is supposed to detect, icing and shut the compressor off and turn the fan on high for a while. Evidently this feature does not work on mine and can not be repaired. No more Maytags for me.
SOURCE: Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
SOURCE: What can I do to
The frost is requried for the unit to do it's work. The unit should routinely turn off and the ice should melt. without this process no water would be removed from the air....
