Radio Communications Logo
R
Robyn Aitchison Posted on Oct 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set up my handheld UH850S handheld UHF-CB Transceiver. We are on channel 40 0 one receiver works prefectly but one has a PRI on the screen and I can call out but not receive answer
The Spaminator
Level 3:
  • Master 628 Answers
  • Posted on Oct 12, 2019
The Spaminator
Master
Level 3:
Answers
628
Questions
0
Helped
142144
Points
41137
5 Related Answers
Anonymous
  • 398 Answers
  • Posted on Sep 01, 2007
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
ccgene
  • Posted on May 07, 2008
SOURCE: i have a handheld cb radio cobra model: HH-35 that doesn't work
I have two Cobra HH-35 WX units available. They are reconditioned, still in the box, and tested but never used. Will sell for both for $30.00 plus 8.98 Priority Mail Shipping. You will have in 2-3 days.
informatica
Greg Cann
  • 1114 Answers
  • Posted on Aug 31, 2008
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Anonymous
  • 44 Answers
  • Posted on May 17, 2009
SOURCE: Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Anonymous
  • Posted on Sep 05, 2010
SOURCE: Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance.
15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ...
8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
2answers
Purchased a midland 75 785 from u s will it work on u k channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
2answers
Midland 75 785 purchase from us will it work on uk channels
  • Hope this helps.
Cobra 75 wx st fuse keeps blowing. As soon as I plug the transceiver into the connector box the fuse blows.
Hi and welcome to FixYa,
Initially, check the reverse protection diode, D18 (1N4004). It would be located / connected at the power board of the DC connector.
Good luck and thank you for asking FixYa.
2answers
Need cb channel frequencies 1 thu 40
Channel list.
There you will find a list of the citizens band frequencies.
Have an old uniden uhf, model vh 011. Is this a 5 watt unit or not?
This radio has a 5 watt transmitter, and works on 40 channels in the UHF (477MHz) band. Called a "CB" but is not marketed for use in the U.S. since "CB" here is 40 channels in the HF (27MHz) band. "FRS" in the U.S. is the "new CB", but offers fewer frequencies and all are lower than 477Mhz. Transmitting with this radio in the U.S. (and probably other places, too) will require a license.
More information about this radio can be found below:
http://www.uniden.com.au/v3/product.asp?ID=36&Group=2
1helpful
2answers
75 WX ST
Other info here.
Informatica
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
