Check your ground and power wire connections. It will most likely be a bad ground, if grounded in the trunk, get a longer wire of equal or greater thickness and ground to either chassis or battery. Also if you have the amp at full gain try dropping it a little back if getting a better ground doesnt help
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So.....
if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
this is a safey feature in your amp. you are drawing too much power for the amp to put out so i shuts off when the breaking point of the total rms calue is reached. i would suggest getting a more powerfull amp, a larger ground/powerwire combo, or a farad capacitor to balancethe powerin andthe power out.
