I don't know. consider pushing a little on door or lid to see ifyou can restart it.. test washer's recepticle - unplug washer and plug in a lamp or anything to test if it is alive.
if alive, plug washer back in making sure plug is in firm.
if not alive, unplug all and locate fuse or circuit breaker at main home panel. note position of breaker then move it off and on a few times then to on position. if fuses, just replace fuse for washer's recepticle with a good 15 amp fuse. plug in lamp to test it lights. if yes then remove and plug in washer. if not OK, resubmit question with make and model and if having breakers or fuses. thank you.
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine.
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch
If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly
Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
