SOURCE: Wiring new RTH2310 DIY Honeywell
is the j2 jumper on the backside of the display set for hg instead of he - g is gas/oil e is electric - if correct take thermostat wires off screws and turn power back on - see if burner fires up with no thermostat wires connected - old wires could be touching somewhere when put on new thermostat
SOURCE: how do I change my DIY honeywell RTH2310
go to
http://www51.honeywell.com/honeywell/
and enter your model number on the right side near the top.
SOURCE: My husband just installed the Honeywell RTH2310
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
SOURCE: Wiring problem?
Yes to everything!!
You have it figured out!!
Just make SURE that the blue unused wire cannot touch any of the other wires, it will wreck your transformer in a split second.!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
Heatman101
