SOURCE: Sharp cash register XE-A41s
Hi. turn key to OPX/Z mode. Press the receipt button. Turn back to REG mode. Now when you want to issue a receipt, press the receipt button.
Mark
SOURCE: Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3. The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
SOURCE: i have a XE-A404 cash register, ive been out the
SOURCE: SHARP XE-A203 CASH REGISTER 1. Continuous
You can try calling Sharps help line at 1-800-237-4277, then prompts 1,1,3,4.
