Frigidaire PLMV169DCD is the model - manufactured in 2006
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Chances are you will end up having to but more than you want to, but not the whole door.
SOURCE: Need a slim over the range microwave
matag can sell you one call them and give them your size....
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
