5e means either the filter is clogged or the pump is not working or the hose is plugged. Drain it first, using the hose. Lay the hose down in a bucket and let it drain out, making sure the bucket or dish can hold all the water. If it does not, bring the hose back up, drain the bucket and start again.
Then remove the filter cover and check for obstructions, and when it is clean, run a limited cycle, and check to see if it sounds like the pump is running. If not, the pump needs replacement.
If it is running, and hardly any water is coming out of the drain hose, quickly move the drain hose up and down to use it as a ram to remove any plugs in the drain hose.
It should start coming out as a solid thumb width sized stream.
SOURCE: samsung p1453 will not drain or spin
5E (or SE error) is displayed if the water level frequency detected is 25 KHz or less
in the initial phase of the UNB -detecting cycle.
The Water Drain error
can be cleared by turning POWER SW OFF and back ON.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day.
SOURCE: I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
SOURCE: Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
SOURCE: SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
