Freezers Logo
J
Jean Pierce Posted on Oct 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire freezer, Model No.LFFH2067DW1, Serial No. WB50332289 has both red and yellow lights shining on the front. Do I have a freezing problem or just a light problem?
Tom Chichester
Level 3:
Top Expert:
  • Frigidaire Master 62,329 Answers
  • Posted on Nov 08, 2020
Tom Chichester
Frigidaire Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672487
Points
975369
Or a control board problem
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 11, 2007
SOURCE: light on freezer
This just means that you have power to the freezer.  It's letting you know it is plugged in.
Anonymous
  • 102 Answers
  • Posted on Apr 11, 2009
SOURCE: Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Anonymous
  • 236 Answers
  • Posted on Apr 19, 2009
SOURCE: What does the orange light stand for on a
fast freeze, switch the f/f button off and see if the light goes out!!!
Anonymous
  • 1218 Answers
  • Posted on Jan 14, 2010
SOURCE: I own a Frigidaire Upright Freezer/not freezing...
Good day,
If the unit is running but not cooling then check the following.
1. The fan motor behind the rear panel is not running, you will have to remove the panel, being careful not to damage the control thermostat, and inspect the motor, and replace if needed.
2. The defrost system has failed, icing the coil behind that same panel, and not circulating air. There are 3 parts to the defrost system, the main heater, a calrod unit mounted on the bottom of the cooling coil, a defrost control thermostat which is located on that same coil, but on the top. It is a small 1" round disk with 2 wires coming out of it.
Lastly, a timer which is located on the back of the machine and determines how often the unit defrosts.
If you have an ohm meter and know how to use it, you can test the heater and control thermostat for continuety if the coil is indeed iced up. If not iced up, the test will not work.
To test the timer, you take a screwdriver and with the machine on, turn the shaft clockwise until it shuts off. wait 35 minutes. If it turns the machine back on, it's O.K. If not, it needs replaced.
A tutorial on defrost systems is at the end of this post.
3. If none of the above work, then it is in the compressor/sealed system. This machine has had many issues in this area and is a serious problem unless...........
The unit is under 5 years of age, then warranty will cover the repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Aug 04, 2010
SOURCE: Frigidaire Freezer Model LFFH2067DW1
you have a low refrigerant charge have the unit recharged
How to turn quick freeze feature off (yellow light) on older Frigidaire chest freezer
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
1helpful
Why isn't it freezing?
Hello friend, thanks for your inquiry!
From the information you have provided your Frigidaire freezer is no longer freezing and all the lights are on. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If this does not start your freezer would you be able to provide me with your model number? You can locate the model number on your serial tag which can be found on the inside wall. I look forward to assisting your further. -Matt
1helpful
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
1helpful
My Frigidaire commercial freezer model LFFH2067DW1 makes a loud, almost rhythmic, knocking sound. What can that mean?
Could be a compressor on its way out, a warped or clogged fan could cause similar sound issues, the valve plates in the compressor could be worn causing pressures issues.
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
