Might be beeping because the batteries are low and need replacing. Battery access is inside the door.
If you have the instructions you might find removing the batteries for a time might lose the combination so you can programme your own, alternatively, you could just remove the batteries and continue to use the key but I strongly suggest you fix yourself up with a spare key and make a note of the number if possible.
SOURCE: buttons dont work on danby microwave
I had the same problem, but only with 4 buttons. The 3,6,9 & Start/Stop button stopped working.
Hard reset & leaving unplugged did not work. Eventually, I tried picking it up and dropping it from several inches, and smacking it on the side. That did the trick. Works great now!
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
SOURCE: sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
SOURCE: Miele dishwasher Advanta Series.
the washer starts runs for 10 mins then beeps and beeps all the lights turns on in the programing panel inside HELP
SOURCE: cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
