Heavy Machinery Logo
D
DAVE GOWAN Posted on Oct 10, 2019
WHERE IS BATTERY LOCATED IN MY 2008 256C SKID STEER?
  • Bergur Ketilsson
    Bergur Ketilsson Oct 23, 2019
    Hi DAVE GOWAN, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is it a Bobcat or another brand?
Hydra
Level 1:
  • Contributor 7 Answers
  • Posted on Nov 08, 2019
Hydra
Contributor
Level 1:
Answers
7
Questions
0
Helped
1492
Points
12
Model 256c means it's a Caterpillar. Did you look under the seat? Since you apparently don't have an owner's manual, you need to get one. Manual should be stored on the machine in a weatherproof case.
5 Related Answers
Timllfixit
  • 2210 Answers
  • Posted on Oct 17, 2012
SOURCE: have jcb skid steer that was running and then shut down at idle. it will not restart. have plenty of battery and the starter is working fine.
Check the fuel solenoid stop control on the injection pump in case the wire's off/loose. This can be tested by a length of wire and 2 croc clips direct from the pos terminal on the batt. If it fires up, the supply via the harness is lost somewhere. It needs a supply to keep the pump running.
Bleed the fuel system, if it fires up, its drawing air into the system. Check seals/o rings on fuel filters and any loose unions.
  • 19187 Answers
  • Posted on Jan 06, 2014
SOURCE: starter stays engaged or blows a fuse when I try to start my skid steer
This could be the starter or the ignition switch, Take the starter out and have it tested. IF the starter tests ok, replace the ignition switch.
Al Kizina
  • 170 Answers
  • Posted on Aug 30, 2015
SOURCE: My mustang 442 skid steer battery dies if it sits a few day I changed the battery and it still does it
Charge the battery, then remove one of the terminal connections. With everything off in the vehicle, touch the wire to the disconnected terminal. If you get a spark, something is draining the battery in the vehicle. Possible light somewhere that can't be seen is staying on.
DIESELMUDDER
J.D. Browning
  • 2760 Answers
  • Posted on Feb 03, 2016
SOURCE: Where is the pedal lock relay or solenoid located on a mustang 940 skid steer
well the relay (or park bypass) for that function is right next to the main fuse panel , I do believe on that model is under the cover by the operators right knee , the parking bypass solenoid is the first valve on the valve block , Follow the hose off the pump to the valve block , it looks different than the others as it's only a single coil type , all the others on that block have two coils , this is the bypass valve , but I will say unless you specifically know there's something wrong with that valve , that's not going to be your problem if it wont come out of park mode , its always a safety switch holding it out !! finding it , now there's a challenge , id just hate to see you waste 90 bucks on a valve an it still wont come off park mode
joeaxe
Joseph Coppeto
  • 360 Answers
  • Posted on Jul 28, 2016
SOURCE: finding a service manual for a 500tx vermeer skid steer.
you can get one from he manufacturer on this page:
S800TX Mini Skid Steer
Need a 1816b Case Skid Steer service manual
A service manual for the 1816b Case Skid Steer can typically be obtained through the manufacturer or a dealer of Case construction equipment. The manual will contain information on specifications, maintenance, troubleshooting, and repair procedures for the 1816b skid steer. Additionally, you can find such service manual on some online marketplaces or forum. It's always recommended to use the original manual that's provided by the manufacturer for accurate information.
1helpful
Can you tell me where is the fuse/fuse box located on a Scat Track skid steer?
In the cab under the left window around knee position towards the windscreen is a a covered box that's it.
Where is the serial number located on a bobcat utv model 3400
How to Find the Year on a Bobcat Skid Steer
  1. Locate the VIN or serial number on your Bobcat. ...
  2. Look through the Owner's Manual for the VIN/serial number. ...
  3. Write down all of the numbers that appear in the Owner's Manual or on the skid steer.
  4. Call the Bobcat Marketing Service Department.
2answers
How do I adjust creating on 1845c case skid steer
CatĀ® Skid Steer Loader ' Drive Chain Adjustment ... - YouTube
? 1:39
https://www.youtube.com/watch?v=FUtx88JifxY
Sep 27, 2011 - Uploaded by CatĀ® Products
CatĀ® Skid Steer Loader ' Drive Chain Adjustment & Chain Oil. CatĀ® Products ... Crane picking a skid steer out of a building. Unsafe - Duration: ...
How to change a drive chain on a case 90 XT - YouTube
? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
Case 1845C Chain adjustment question - Heavy Equipment Forums
www.heavyequipmentforums.com/showthread.php?...Case-1845C...adju...
Mar 6, 2012 - 15 posts - ā€Ž5 authors
I noticed it was making a popping noise in the front left wheel, so I. ... It appears that this skid steer is pretty much indestructible if taken care of ... Case 1845c Skid Steer Problem - Heavy Equipment Forums
Apr 21, 2013
Case 1845C Uneven speed while travelling
Nov 24, 2012
1845c what things go bad - Heavy Equipment Forums
Jun 9, 2009
1845C Fan belt change question - Heavy Equipment ...
Apr 9, 2009
More results from www.heavyequipmentforums.com
Where is battery located on Cat 246C skid steer?
The Battery is under the Back seat take out the bolt on the bottom right side of the seat pull up on seat
Jul 28, 2012 • Toys
Bobcat 600 distribritor cap firing order
Bobcat 600, 600-D, 610, 611 Skid Steer Solution Handbook Download! br This Bobcat 600, 600-D, 610, 611 handbook is a detailed data and it is cited clear detailed instructions. Bobcat, Melroe, Clark, Ingersoll Rand 600, 600-D, 610, 611 Skid Steer Loader Repair Shop Repair Service Manual.
Bobcat 600, 600-D, 610, 611 Skid Steer Service Workshop Manual
Top Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
