I have a Nokia C3-00 and had to have a new OS put on it, and as a result the data internet does not work I want to get this phone working as it's a solid phone I know it's old but it's solid If you can help me get the APN and Data settings to access internet via data on this Nokia C3 please do. Thanks https://en.wikipedia.org/wiki/Nokia_C3-00
SOURCE: Cect p168 problem internet & MMS settings with Rogers Canada
I Have a question ... How can I change the theme on the Cect p168 ??
SOURCE: SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
SOURCE: Access internet on pc though Nokia E 63 Mobile phone.
yes. just connect your phone to your PC and open network connections... from there, you can choose to open internet using the network provider by your phone's GPRS
SOURCE: how can i format my nokia c3 phone? i cant access
you cant format a mobile you can only reset it to factory but listening to your fault i would say your keypad is broken
Please check your phone sw version from this link and update if necessary.
Please do not forget to back up your phone before you update.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
The latest sw is 4.60 depending on the sales areas and variant.
Please also become familiar with the FAQs :
http://europe.nokia.com/support/search?comp=Nokia+C3-00&qt=wlan
How do I manage WLAN internet access points on my Nokia C3-00 device?
How can i use always WLAN connection on my Nokia C3-00 phone for Internet instead of GPRS?
I hope this helps.
First of all you delete all current settings, these are for 02 and will not work on giffgaff. To delete settings: Now that you have done that you need to set up the giffgaff settings, I recommend using this method to do it: Now that you've done this set up the packet data settings: Okay so finally for wifi settings: Now you have giffgaff internet and wifi set up on your Nokia C3-00! For any issues you can message me, I will be willing to help! Update: You may be experiencing problems with using wifi with the browser or any other application, do this to fix it: "I had the exact same problem. What I did was that I removed all network Internet settings, GPRS, WAP, etc. because I do not want to use them which is when I lost the ability to select which AP to use. So what I did was I created a personal setting: Settings > Configuration > Personal settings > Add > Web Then go to the main menu > Internet > Web settings > Configuration Settings > Select the personal settings that you created Now try to access the internet and it will ask you to choose, choose Wi-fi Then go back to the personal settings and delete the setting that you created. From now on, you will be asked which connection to use everytime you access the internet If you want to restore your GPRS settings, you can just request it from your network provider and they will send it to your phone." Source http://discussions.nokia.co.uk/t5/Cseries/ANOTHER-NOKIA-C3-WLAN-PROBLEM/td-p/754515
