SOURCE: having trouble lighting a second
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
SOURCE: Have an efel oil stove, it lights ok but the crown
The gas orfeces are pluged up you need to take a wire brush and cleen them.
SOURCE: just looking for any info. on efel harmony 3 wood
Please get it here :
www.fireplaces-oldham.co.uk/Euroheat_Harmony_Classic_Multi-Fuel_Stoves.htm
Multi-fuel > Nestor Martin">www.murphyheating.com > Multi-fuel > Nestor Martin
Kind regards, Jay
