Samsung SCX-4828FN All-In-One Laser Printer Logo
Anonymous Posted on Sep 17, 2009
Paper jam --samsung SCX-4828FN
I had a paper jam and took out the paper. follow the notice - open and close the door. and tried again and again, the problem was still in it. confused! what should i do?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2560
Points
I found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
My samsung scx 4828fn is showing out bin full
This could be related to a paper jam or a problem with the paper full sensor not moving freely. Turn off and unplug the printer. Remove the paper in the output tray. Check for a paper jam at the output. Look for anything blocking the sensor on the left side (or center) of the output tray. This sensor is a little plastic flag that should move freely as paper flows into the output tray. (This will be on the roller at the exit of the paper flow path at the output tray.) Try flipping it gently with a finger. If it is stuck, try to loosen the sensor; you may be able to clear the problem using canned air. Note: the flag can break if too much force is used. If the flag remains stuck or is broken then the printer requires repair. If the SCX-4828fn is out of warranty, decide if it is worth repairing. If it is less than a year old, contact the manufacturer.
I hope this helps.
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
2answers
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
2helpful
The printer say paper jam 1 open close door
First remove the toner cartridge.
Move manually the gear of the toner cartridge (big gear) forward and place the cartridge in your printer and try again.
I'm trying to print and i always get a paper jam in door one. If I open the back door, the paper comes out 1 inch and stops. The paper is getting 95% printed on and then gets jammed. I changed the toner...
1. You have to clear paper feed roller
- to do this just follow simple steps:
- open fron cover
- remove toner cartridge
- use wet cloth (water or alcohol) to clear rubber feeder
- put toner cartridge back
- close front door
2. If the problem persist - chek all paper path sensors for lack of moving.
1helpful
2answers
My paper is getting stuck on roller for laser printer scx-4521F, when remove paper and open door to reset printer, paper goes through and then jams again on new job.
open the front door and take the cartrige out.
if it jams at the black roller. you must clean the pickup roller.
you will see it at the back of the unit in the center.
1helpful
2answers
I have a paper jam in the back of the machine how do you get the paper out?
open the back door,see where paper jam,could be wrapped around fuser.if no jam,fuser or output sensor faulty.
2helpful
Paper jam error, check everything but still showing paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
