Air Tools & Compressors Logo
raymond yohn Posted on Oct 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS A E02 CODE ON 25 HP GARDNER DENVER SCREW COMPRESSOR
Joe Garcia
Level 2:
Champion:
  • Expert 210 Answers
  • Posted on Mar 27, 2020
Joe Garcia
Expert
Level 2:
Champion:
Answers
210
Questions
0
Helped
76210
Points
392
A bad temperature or pressure sensor
5 Related Answers
Anonymous
  • 89 Answers
  • Posted on Mar 14, 2009
SOURCE: we are looking for a manual on both a gardner
I CAN PROBABLY HELP W/ THE GARDNER DENVER BUT HAVENT HEARD OF AIR TRACK. CALL ME AT C&A EQUIPMENT SERVICE @ 919-231-8700 OR EMAIL AT [email protected]
Anonymous
  • Posted on Jan 12, 2010
SOURCE: We are looking for parts for a Gardner Denver air
i have the unit you need. i have the entire compressor. need 250.00 for the whole compressor, must be picked up phone 270-830-9894
elunsford
  • 229 Answers
  • Posted on Nov 16, 2010
SOURCE: gardner denver air compressor is blowing oil, need
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Anonymous
  • 1274 Answers
  • Posted on Dec 02, 2010
SOURCE: gardner denver 450 pumping oil
Hi alan, my name is John. Welcome to FixYa. try loosing the valve at the bottom of the tank and bleed all the water and stuff out until nothing comes out. Thanks for choosing FixYa....John
Vernon Taylor
  • 7446 Answers
  • Posted on Jul 13, 2016
SOURCE: have a Gardner Denver Electra Saver 2 compressor and it is not getting power to the control unit to start?
This is probably an industrial unit powered by a three-phase electricity supply.
If this is correct, the available current and voltages available at the supply are potentially much more dangerous than a domestic single phase supply. Great care, experience and properly rated tools are a must for locating problems.
3-phase motor control units can be quite complex and it is wise only experienced persons get to fiddle around with them. As no supply is reaching the control it shouldn't be an issue unless the supply is wired directly into it instead of employing a separate junction box.
If there is a junction box where the supply enters the unit, this is the place to begin checking if it is decided the supply is leaving the nearby wall-mounted main isolator and fuse unit - check the fuses first.
I HAVE A GARDNER DENVER 25 hp MOD EBEFFD ser m90917. Is 1/4" line that goes into the side of the cooler is an air line or an oil line. I do know that it is a temp monitoring line. dont know which.
According to the diagrams for those, it appears to be an unloader line which means the compressor unloads after stopping via the center of the crank shaft. It would therefore be an air line.
2answers
Have a Gardner Denver Electra Saver 2 compressor and it is not getting power to the control unit to start?
Is this something new you just installed? Is it not getting electrical power to junction box? If your getting 220 volts of power to unit is there a reset button or reset protocol? Thank you Sylvia and good luck. Make sure breakers are on. Please consult an electrician to obtain your power issue.
Need manual for air compressor 5 rca
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Gardner Denver
4helpful
Gardner denver air compressor is blowing oil, need help
2answers
We are looking for parts for a Gardner Denver air compressor. ADA 1006. We need piston rod and rings.
Your looking for a rebuild kit for a low production, high end compressor pump. You have two choices. The first is to search and maybe stumble across the parts you need, I have a better chance at finding the parts and I know it will take a while. The other choice is to contact a supplier for the kit. It will be a lot quicker. Trust me.
Try the link below. Just fill out the info and if it's available they will find it. In the mean time I will try a couple other sources and if I find anything I will post it here. The second link is direct to Gardner Denver.
Hope this helps.
http://www.aircompressorsandparts.com/Gardnerdenver.htm
http://www.gardnerdenverproducts.com/Compressors/SalesAndServiceLookup.aspx
We are looking for a manual on both a gardner denver air compressor and a Air track with hammer
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
