Washing Machines Logo
Sally Kelly Posted on Oct 10, 2019
How do I remove the soap/softener drawer in the WM2487HWM to clean it? It is nasty.
Derick Bartelings
Level 1:
  • Contributor 25 Answers
  • Posted on Oct 12, 2019
 Derick Bartelings
Contributor
Level 1:
Answers
25
Questions
Helped
21943
Points
88
See this on youtube
https://www.youtube.com/watch?v=Ee0fqtb9jjQ
5 Related Answers
Anonymous
  • Posted on Nov 23, 2008
SOURCE: clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 28, 2008
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 17, 2009
SOURCE: Compartment 3, detergent dispenser, fabric softener.
Grasp the drawer firmly, and give it a good tug to pull it out.
Remove all parts, and thoroughly clean, then just line it up with compartment and push it back in.
Plz rate my solution.
Thanks.
Anonymous
  • Posted on Apr 11, 2009
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Anonymous
  • 1543 Answers
  • Posted on May 23, 2009
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
1helpful
Samsung vrt washer
it is probably the water valve for the softener has failed nachines have one valve for the cold rinse water and a second valve for the softener compartment in the soap drawer
WATER LEAKING from Soap / Softener dispenser
Close the water faucet slightly to reduce the speed of the flow into the the soap drawer...The machine will fill a little slower, so what??!
1helpful
LG front loading washing machine. The softener drawer does not fill with water and therefore does not drain. The soap drawers either side of the softener drawer fill with water ok. I have cleaned the...
There is a solenoid valve to let water into the softener compartment ....this must be faulty. You could take out the drawer and thoroughly clean it. it might have a stoppage in the drawer entry. Softener can cause greasy build ups.
1helpful
My indesit front loader WG623 is not emptying the softener compartment . I have removed and cleaned the soap and softener comparntment properly...
Thoroughly clean the top of the soap drawer compartment with a stiff brush or similar, poke a piece of wire into each individual hole in the top of the compartment.
Make sure the the syphon tube is not blocked in the soap drawer.
Fabric softener doesnot seem to work
Open soap drawer and remove little 'hat' from it's post in the fabric softener compartment. Make sure both are clean and free of softener residue.
2answers
My machine is collecting water on the fabric softener dispenser and also on the soap dispenser
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Fabric Softener dispenser is holding water that will not drain.
remove soap drawer and dismantle softener syphon assy , clean and reasemble , whilst drawer is out check water jets in roof of soap container , clean all but especially ones over the conditioner compartment, replace drawer and re-try.
65helpful
2answers
2helpful
2answers
The machine wont take the fabric softener.
Remove soap drawer from washer, and remove all accessories,and thoroughly clean all parts, particularly the conditioner parts, make sure the syphon tube is clear by poking through it .
Clean interior of soap drawer compartment with a stiff nylon brush or similar.
Thanks.
Top Washing Machines Experts
john h
