Vacuums Logo
S
Shelley Brierley Posted on Oct 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dyson V11 absolute is fully charged, no power, button feels dead.....
brian kossman
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 74 Answers
  • Posted on Nov 04, 2019
brian kossman
Expert
Level 2:
Welcome Back:
Answers
74
Questions
0
Helped
78666
Points
101
If it is pulsating, it needs to be tuned up. No power, replace battery.
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Dec 30, 2016
SOURCE: Dyson cordless v6 vacuum keeps shutting off. Fully charged. Max button off.
I would suspect the battery pack is defective.
Where are 2 fuses on a Dyson V11. My V11 won't turn on. I've replaced the battery and put on a new filter.
This confirms there are 2 fuses but not where?
Is There A Fuse In My Dyson? Yes, there are 2 fuses in your Dyson vacuum that you should know about. The first is a standard electrical fuse that prevents damage from faults like short circuits and power surges. The second is a thermal fuse that prevents the vacuum motor from overheating and damaging the appliance.
There are two disassembly videos here that _should_ show the location.
https://www.google.com/search?q=dyson+v11+fuse+location
1helpful
2answers
Dyson v8 absolute is fully charged yet cuts out after 20 seconds of running. If we plug it back into the charger for a couple of seconds it starts again
If not battery low, check for blockage. Go to following Dyson link on how to...
https://www.dyson.com/support/journey/troubleshooting/164545-01.html
2answers
Can I use dyson v10 cyclone absolute with partial charge without hurting longevity of the battery?
As long as you don't run the battery completely flat, it won't hurt the battery.
My Dyson v8 absolute stopped working while vacuuming...I plugged it in to charge and I get a flashing blue light.....what could be wrong
Blue flashing light means battery has no power left . You need to recharge battery again . Fully charge battery before using it .
2answers
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
The brushes on my Dyson V6 sweeper attachment won't turn although it is fully charged.
Your battery may indicate fully charged but if dead it will do that and not work for squat. If charged the motor should run and turn the sweeper with power. If motor runs but sweeper does not check for a stretched belt or one that may have fallen off the pulley.
My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
