SOURCE: Water Filter location
the filter is in the toe grille under the freezer door ...it is a filter pn#4396508 you should be able to get it at Home Depot/Lowes
SOURCE: Reviews
If you have not had it for the full warranty period, by all means. (I would call their Customer Service number first.) Here is the site for phone numbers:
Home Depot Contacts
You might also be interested in this website. You might use this for "ammunition".
http://www.consumeraffairs.com/homeowners/charmglow.html
SOURCE: Stovetop lamp sockets very brittle and are disintegrating.
In effect (given the unit is wired correctly) without insulation on the socket, you have an exposed neutral wire in your oven -- this is certainly not as dangerous as an exposed hot wire, but does present risks. I recommend replacing the light sockets -- you'll sleep and cook a lot better.
SOURCE: I purchased a Magic Chef under cabinet microwave
Since it's a clearance item, it may not have a warranty.
But you should check with Home Depot on that if you haven't already.
Otherwise, you'd have to have it repaired yourself.
We see (and repair) this a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at
our Web site, along with a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Where can you purchase replacement
You use www.homelite.com part lookup for the HU80709. Homelite site doesn't list the a version but parts should be the same. www.jackssmallengine.com is excellent source for parts and is very reasonable on the parts.
