Dishwashers Logo
Donnie Dotson Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor running but not washing
Set dish washer on normal cycle but later discovered that the motor was running but not washing. When I opened it I discovered that the motor was running (unit making noise and it was set on 30.) Dishes were still dirty.
Ronald Rissel
Level 3:
Master:
  • Dishwashers Master 715 Answers
  • Posted on Oct 13, 2019
Ronald Rissel
Dishwashers Master
Level 3:
Master:
Answers
715
Questions
Helped
259065
Points
1075
You didn't mention what brand dishwaser you are talking about, but if it is a Bosch, they are known for having the impeller (which is in 2 parts) coming apart, so the part of the impeller that has the blades doesn't turn. In other dishwashers, I've seen the holes in the wash arms get clogged, especially if you don't have the removable filter installed correctly, or (if it's a GE), the filter plate on the bottom gets warped, allowing bood and debris to get in the wash arms and clog up the holes. We really need to know the brand and model number of the dishwasher (or any appliance) to be able to help you accurately.
5 Related Answers
Anonymous
  • 249 Answers
  • Posted on Nov 28, 2007
SOURCE: motor noise
it could be something caught in motor empeller IE. a bit of glass, or motor could be faulty
Anonymous
  • Posted on Jan 10, 2008
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Anonymous
  • 1314 Answers
  • Posted on Jan 17, 2008
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
douglas smith
  • 1462 Answers
  • Posted on Sep 07, 2008
SOURCE: dirty dishes
if water comes into machine then valve is ok.
open machine when in cycle and look to see if spray arms are rotating
if not, then take out and clean.
spray arms only rotate with water jetting out of angled nozzles at end and if these are blocked then no rotation and poor wash
Anonymous
  • 3741 Answers
  • Posted on Aug 29, 2009
SOURCE: Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
1helpful
2answers
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 • Dishwashers
2answers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
4helpful
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Dishwasher does not go into the wash cycle the other cycles work but it does not wash the dishes .when I open the door the soap is on the bottom of the dish washer .T he water comes in rinses the drians...
you'll need to determine if the wash motor is running during the wash cycle(listen for noise from the motor). If the motor is not running there is an electrical problem possibly in the motor or the timer. If motor is running but not washing, the pump impellor maybe loose on the motor shaft. The impellor was press fit onto the motor shaft and cannot be retightened. The motor and pump assembly would have to be replaced, somewhat expensive to do.
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 • Dryers
2helpful
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
2helpful
4answers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
