If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Thin white horizontal line center of screen!
The set should have a vertical output IC,You need to change it ,maybe you can check the B+ going to it because it might have opened the safety resistor if the IC went bad.You can check for broken board too unless the set is never move from one place.Be carefull when checking voltages ,there is still high voltage,not much but can num your whole hand.
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
SOURCE: vertical line in my toshiba laptop
Hi...there,
Check the flat wide cable that attached to the panel, it's might be loosen a bit. Sometime cable got pulled when lift open the screen. If not, then you got a busted panel...
