You have to remove the 7/16 bolt from the top of agitator. then transmission should drop out
I am working on a Kenmore Series 80 Washer, a 1986 - agitator calypso agitator1417523267236-undefined-undefined-5.jpg523267236-undefined-undefined-5.jpg" alt="agitator calypso aI am working on a Kenmore Series 80 Washer, a 1986 - agitator cap removal-undefined-undefined-9.jpg" class="h_mi" />
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
SOURCE: dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
SOURCE: 80 series kenmore washer
Try this:
http://beta.searspartsdirect.com/partsdirect/partsdirect/getSubComp.pd?diagramPageId=00004&documentId=P0012168&modelNumber=11010202001&productCategoryId=0153200&brandId=0582&modelName=&blt=06
