Sounds like timer is bad
Manual appears on following link:
http://waterheatertimer.org/Programmable.html#59745
Troubleshoot for analog timers appears following link:
http://waterheatertimer.org/How-to-troubleshoot-timers.html#59017
SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
SOURCE: have a new woods tn300 light timer. if lift the
Anywhere that pegs are pulled up is where the outlet is off if the pegs are down then the outlet is on. Hope that helps!
SOURCE: I have woods lighting timer
See Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Are you sure about that model number?
59200 is a plug-in dial-type timer.
Timer does not have a light.
The dial is rotated to set current time.
And segments located around dial are pulled up and pushed down to set timer function.
http://waterheatertimer.org/pdf/Woods-59200.pdf
Add a comment with description of your so I can locate manual and help.
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: HOW DO I SET THE
with a timer like that , start here. Unplg it and have it in your hand. Pull up all the tabs. Push down the tabs from 7pm-6am. Now, find in the center ot the unit, the little arrow, turn till the correct time, the the right now is at the arrow. Plug in right away. As for the timer switch, timer on will work just as timer, push to outlet on will turn the lamp on manually. Also keep in mind that if the power goes you will have to realign the arrow with the actual time.
