SOURCE: how many volt , ac.or dc. for power supply phonic MM1202 mixer
I tells the power supply model numbers on the back of the unit above the power connector plug. It doesn't tell the specs as of how many amps but does describe several voltages of AC it would work on and also gives several model numbers of the correct power units that are sufficient. If you don't use one the recommended units, it could malfunction and give extra static noises caused by improper filtering of the power. It shows on page 8 of this manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=39&ved=0CHkQFjAIOB4&url=http%3A%2F%2Fsoundhouse.co.kr%2Fsoundh%2Fcatalog%2FPHONIC%2Fmixer%2FM-U-1-2-0-2_1-2-0-2-X_om.pdf&ei=QPdbUaX3K4zA9gS11IFY&usg=AFQjCNGoMutp27pESma_-Mw36637hlmHOA&sig2=8J0-4rb6sHlit-OdKlIFbg
I hope this helps you.
