SOURCE: I need to replace a switch for my trolling motor
Hi, If you picked the right header and it is a Maxxum 55 then it is a 12v motor. So you should hook up your batteries in parallel. This should Fixya!
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
SOURCE: trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
SOURCE: I found a vacuum hose hanging and dont know where
The correct diagram for your engine is located under the hood, Look on the radiator support, firewall, or sometimes on a valve cover...
SOURCE: Washer is leaking from seal around door found a
The spring go's to a wire that snaps around the outside of the gasket. It will be in a grove and hard to find. The spring will hook between the two ends of the hoop wire. Good luck it toke 4 hands to get mine back on.
