SOURCE: not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
SOURCE: I have a JVC GR-D30U
This is a mechanical problem with this JVC GR-D30U that alot of user are also having problem , what I can suggest you to do with this is to take it to JVC service center and hopefully they can fix it since alot of problem are reported with this type of device and it ended up being replace....
Good luck............
SOURCE: JVC GR-DV3000. Goes to
If camcorder accepts normal MiniDV tape without any problem and you can record or playback it correctly then please try another brand video head cleaning tape as existing head cleaning tape might be not good that is why camcorder rejects it.
Hope this will help.
Thanks.
SOURCE: I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
