I consider the instructions at bikewebsite.com to be inadequate. The best instructions for bike repair tend to be on the parktool site:
https://www.parktool.com/blog/repair-help
Yes it can, This web has diagrams and instructions with pictures,http://www.bikewebsite.com/rhub.htm.
SOURCE: Bicycle Rear Wheel Problem
You may have buckled your wheel if its a spoked type ! If you have buy a spoke key and tighten the spokes opposite the buckle .............ie if the buckle goes over to the left stop wheel and tighten spoke that lie on the right of the rim ..........it fairly easy if your rim is not to badly damaged..... you will have to keep on tinkering to true the wheel up.......ps also check your spoke are tight before starting as i have seen spokes just loosen for no reason.......hope this helps.
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
SOURCE: 1998 Mercury Mountaineer wheel bearing
2x2 = nothing special since they are old fashion tapered bearings
4x4 = nothing special again BUT the wheel bearing is part of the hub assembly!
SOURCE: repair front wheel bearing assembly
no special tools in particular just the usual or necessary tools required.. 1stly u remove the Tyre and the caliper then u'll see something like a long rod dats the bearing
