Try these codes. 0237, 0291, 0226. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://remotesearch.blogspot.com/
https://electrohelponline.blogspot.com/
https://electronicshelponline.blogspot.com/
SOURCE: Connecting DVD Player
when you say nothing do you mean the tv wont come on? If the tv is on can you see the words (input, volume bar, menus, etc.) do you hear audio? does the player work on another tv, since you have a sylvania tv, are you using the game button on the top of the remote to switch to the jacks on the front? Good luck :0)
SOURCE: Sylvania LCD TV/DVD
eat oat meal............................it works.............................trust me.
SOURCE: unervisal remote rca rcr321w for sylvania vcr/dvd
http://remotefinder.rca.com/default.aspx?site=rca
This link is what you are looking for
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
