SOURCE: DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
SOURCE: RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
SOURCE: My Tv suddenly will not tune to a channel
please help in unlocking my broksonic CTVG-5463GVC
SOURCE: Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue. The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device. And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room. This may require closing a door or drawing heavy drapes closed.
SOURCE: The two TV are synced. Do I unconnect them?
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
