We've had trouble in the past with the washing machine not spinning out after rinse, or clothes still soaked with soapy water after all is said and done. I removed the front panel and watched it go through a cycle in which it did run a final spin. Here are the steps the machine took: 1. Filled with soapy water then agitated at each dial marker (heavy, medium, light load). 2. Drained the soapy water until empty, but did not spin the soap water out. 3. Went to rinse cycle, but only filled up with water half the amount the wash cycle, but not enough to submerge all of the clothing. 4. Did not rinse and spin, just drained the half amount of water until empty. 5. Spin I was sure I've watched washing machines do a rinse while spinning in order to get all of the suds out of the clothing. This one did not. This particular time where I watched it, the clothing was spun out at the end, but as I mentioned earlier, that is not always the case.
SOURCE: Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
SOURCE: GE Top Load Heavy Duty Washer only works for small loads
Sounds like you need a new drive belt.
Testimonial: "Is this drive belt difficult of change? ... Are the belts expensive? Now I know, where to start looking at least. Cheers! "
