Do you mean the Dynex ZRC-102 remote control? This remote was included with the Dynex DX-LCD19-09 and a few other models and is not apparently a universal remote control. The guide to the remote is usually included in the manual for the electronic device that the remote came with. The best source for the manual is ManualsLib, https://www.manualslib.com/manual/41507/Dynex-Dx-Lcd19-09.html#manual . Pages 5-6 describe using the remote: https://www.manualslib.com/manual/41507/Dynex-Dx-Lcd19-09.html?page=5#manual . Unfortunately, the manuals here, https://www.dynexproducts.com/pdp/DX-LCD19-09/8632848 , are not readable by my Windows computer. I don't have a Hex or Octet reader installed.
I hope this helps.
SOURCE: my volume control on remote doesnt work
Try the following first;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If you are still having problems, you should return the unit to the place of purchase for a replacement.
SOURCE: i need the code the
Download this PDF for Dynex TV codes, look for the table of common codes, then simply copy it and enter it.
SOURCE: when I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
SOURCE: Need User Manual & Remote Control
I set up this link that will take you to download your When you get scroll down and select there, select download
http://www.manualowl.com/m/Phillips/FW-C579/Manual/163091
