My dog chewed the remote to my Vizio Tv..65 inch smart vizio tv...can I purchase a new one
I'm leaving the link here for you to order a replacement https://support.vizio.com/s/article/How-to-Order-a-Replacement-Remote?language=en_US
SOURCE: Can't find codes for universal remote -- purchased for Vizio TV
Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either.
They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
SOURCE: remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
SOURCE: vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
SOURCE: register my new vizio tv
Try this link:
https://crm.admin.waca.com/WaCA/WarrantyCenter/registration/secure/Vizio/Registration.jsp?masterModelOID=SF-1116689077-37635&purchasePrice=500
If it doesn't work, they must be having problems.
I would try the Customer Service Hotline to get this product registration problem solved.
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
