Air Tools & Compressors Logo
A
Anonymous Posted on Oct 04, 2019
What is the size this compressor nd52labm - Air Tools & Compressors
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Oct 05, 2019
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
499711
Points
3432
Please provide better information for a better answer
I want replace compressor. Compressor number ND52LABM
to replace the compressor you will need specialist equipment including an oxy set, pressure gauges and a bottle of refrigerant
the cost of replacing the compressor make a new fridge very attractive , as you will be told by fridge mechanics
just be very sure because a lot of apparent compressor problems are attributed to the start /run capacitor failure
I recommend a talk with a fridge mechanic to be sure before you open the system
How many horsepower is nd52labm
There should be a "data plate" on the motor. The motor's HP should be listed in the information.
Installed new breaker just for the compressor and it still only runs for a second or two and kicks breaker
You need to find out how much amperage the compressor pulls and make sure the wiring and breaker are sized correctly.
If they are sized correctly then you likely have an issue with the motor or the compressor itself causing the breaker to operate.
Need compresser for lg model nb g.r.m392ylq compresser nb nd52labm
Here is a tip that will help you with the onlinebuying...
How to Buy Appliance Parts Online
heatman101
Need new compresser model nb nd52labm
You can order the compressor from the link below, just type your model number in the search box.
http://www.appliancerepairlesson.com/
1helpful
Connecting the compressor to a tank
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Wire size
I used to know all this stuff, the hardware store has a gauge guide to show you the correct size, i would guess that 8 would be ok, 10 would probably do it, hope this is right.
Compressor blows breaker switch
what size compressor? what size circuit breaker? what voltage? starting with air in the tank or without? it all makes a difference!
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
